1 - 8 of 8 Posts
· Registered
Sooooo my 87 New Yorker (FWD) has the digital climate controls, and the buttons have always been finicky until it warms up inside the car. Then, you have to press them "just right" or wiggle the button for it to result in the desired change. Now, that doesn't work and I cannot adjust my temperature or fan speed.
Looking on eBay, and there aren't any that are like mine. The ones on eBay are for LeBarons and have an "AUTO" button (my New Yorker doesnt have that option so not sure if it will work).
Years ago, I had an 87 New Yorker too and when this happened, I just ventured over the local junk yard and got one out of a crashed New Yorker; that was 22 years ago. Now there are NO crashed New Yorkers in the junkyards.
Looking for solutions... Has this happened to anyone else? Is there a way to disassemble the climate head unit and "clean" behind the buttons or something?? Any tips are appreciated.
Mine looks like THIS but is silver in color, and does NOT have an "AUTO" button:
Circuit component Audio equipment Electronic instrument Office equipment Gadget
· Super Moderator
Looks like an ATC head. Mopar # 3848576. Save your old one, it may be rebuildable for a spare?
Arizona Parts shows 6 of them.
Rectangle Font Musical instrument accessory Bumper Gadget
Gas Rectangle Machine Composite material Electronic device
Rectangle Font Brand Logo Parallel
· Registered
1986 LeBaron convertible, 2.2L T2 with A413. 1989 J convertible dash and console modified to fit.
I have one of those I was given as the individual thought it would be a spare for mine. It isn't as I have the full electronic system from a 1992 Imperial in my Lebaron convertible.
· Registered
Discussion Starter · #4 ·
If it looks exactly as ImperialCrown's picture, and you aren't going to use it & it works, would you be willing to part with it for a reasonable price?
· Registered
Discussion Starter · #5 ·
· Registered
Probably $35 + shipping. One of the mounting tabs was broken but I repaired it before I found it wouldn't work on my system. I will have to find where I put all of those pieces as I had the wiring portion removed from a harness and a vacuum and power unit (goes on the front of the HVAC case).
· Registered
I think years back I had to replace the push button switches behind the panel on mine - yes those are cheap switches just like the navigators I have rebuilt a couple of too.
· Super Moderator
The 6mm 'tact' switches are available generically. They can lose their 'spring-back' after awhile.
Rectangle Automotive tire Auto part Font Event
Reactions: AceHanlon
1 - 8 of 8 Posts
