1 - 4 of 4 Posts
· Registered
Sometime in the past week, the van has stopped starting with a fast idle.
Before this, when I turned off the engine I would hear a whine like a small motor. When I next started the engine it would idle fast for a moment or two before shifting down to a lower rpm idle.
Because it's the summer, the van still starts but once it turns cold I'm sure it won't continue.
I don't have the terms for these parts so it's hard to even look them up in my Haynes book.
If anyone could give me a description of what's going on (or not, at this point) and some possible causes, that would be great. Thanks.
· Super Moderator
Any fault codes or 'ck eng' light? There is an electro-mechanical throttle (AIS) motor on the side of the throttle body on early TBI engines. See #16 here.
It may have stripped its plastic gears if the push stem is no longer moving the throttle lever open and closed. It may not set a code.
Haynes may not offer much detail on EFI components.
· Registered
Discussion Starter · #3 ·
No check engine light.
Just doesn't go through the windup it used to do after the ignition was turned off and doesn't rev at high rpm for a few moments after the engine catches at startup.
I'll look into a pay pal account so I can buy the 1989 service manual on eBay.
thanks.
· Registered
Discussion Starter · #4 ·
The automatic idle control motor seems to be running again. I've had the van in a shop for a week and when he started it up after the repairs he said it wound up as normal and it did it again for me on the drive home.
The morning I drove the van to the shop I had to boost it because the battery was so low. The mechanic said he had no problem with the battery when he started it up.
I wonder if there was something grounded out on the AIS motor and that was draining the battery. Time will tell I guess. I won't bother changing the unit until the problem returns.
1 - 4 of 4 Posts
