1989 Grand Voyager-- 3.0 liter --Auto tran.-- 250,000 plus miles but with different tran (third) ,engine and SMEC 'computer'.
PROBLEM: Engine dies if the AC is turned on doing idle or when pulling into a parking space and turning hard left/right, low speed.
The compression for all cyl. was at 120 psi.
Doing timing check , it was erratic by about 5 degress.
No error codes.
2 years ago the car quit and did not needed it, so it was parked. The van was needed by my son, finaly finding a job in Los Angeles Cal., troubleshoot and found the fuel pump and filter bad. The trip to LA from Idaho went with no problems ,1200 miles and had about 22mpg.
I do hope it will pass the Ca. smog tests after replaceing the cat. , it is gutted.
Thanks for reading and helping me out.
No error codes.
