Hello,
I have a new problem with Sundance...I was attempting to start the car, while rotating the key from "run" to "start", for a split second the engine cranked, then the key continued to rotate, the engine stopped cranking and the key was stuck in a position past the "start" position. I attempted and failed several times to get the key back to the "start" or "run" positions. Finally I was able to Gorilla it back; upon freeing the key and returning it to the off and attempting to start the engine again, it simply rotates through run, start and further past start but the engine doesn't crank, even for an instant.
I have a replacement steering colume with the key lock and all components. I hope that I can replace the key cylinder and correct the fault. Has anyone ever experienced this problem and might I be on the correct path to solving this isue?
