My 90 Sundance needs its left rear upper shock bolt stump removed. THe head broke off despite plenty of lube. Trying to hammer it out is difficult since there isn\t enough room to give your 3 pound hammer+ a drift or small bolt + a good swing.
IT is soaked and will turn from the nut (fwd) side, but won't budge. I wish I could press it out, but there's no room for a c clamp.
I'm, concerned about using propane so close to the filler neck!
You thoughts...
You thoughts...
