There is a what looks like a screwed in plug adjacent to and slight lower than the speedometer pinion. My question is, if I undo the plug, will I be able to drain fluid from what will be an open hole? I can't find ANY reference to what that plug is for. I am plulling the trans to replace the rear block freeze plugs and I don't want to drop the pan as the tranny was recently rebuilt. Trying not to make a mess as well,.... but I may have to pull the dip stick tube. Thanks.....mike
