I just picked up a 91 dodge dakota that one of my friends spent a bunch of $$ on replacing almost everything. plugs, wires, coil, distributor, are all new. I saw posts on corroded wiring by the battery so I dug into the harness on both sides of the truck actually but haven't found any corrosion inside the harness. Had a little on the grounds on the body so cleaned those up. I noticed while cranking that the tach needle jumps so I'm thinking it's recieving signal from the pick up coil in the distributor. I pulled the computer plug and pulled the computer out, found a mouse nest inside so cleaned it out. I'm not sure if the nest had been in there before it quit running or if it could be the reason I have no spark. There is a heatsink inside that the nest was built around so it would've definitely made it get hot if it was in there while running I'm sure. I'd hate to buy a computer though and find it's not the problem. Oh, also checked codes and only get 12 and 55. Is there anything else I should check or is a new computer in order?
