Hi, I am trying to fix a 91 New yorker for a friend. The car is not turning over with the ignition. Tested starter(it's good), replaced ignition switch(nothing, still wont crank), i took the cover off the starter relay in the underhood fuse box and pushed the connection closed and the car starts. so my question is it the actual key cylinder that's bad not letting the car start with the key???
