92' and 94' Le Baron production code plates
500 views 2 replies 3 participants last post by  valiant67
#1 ·
Where on a 94' and 92' Le Baron convertible are the production codes for build options and equipment located on these cars? Also where can I get the decode information for those codes? Any input greatly appreciated. Thanks, Ray
#2 ·
The Body Code plate includes the Trim Code, Paint Codes, Vinyl Roof code, Build Date, etc.. The plate is located under the
hood on the left front fender side shield or wheel housing or the radiator support.
1992:
1994:
#3 ·
You might try this site:
It may have some of them. Problem is some codes get reused so if some seem odd for your that's why.
The only way to get a truly accurate decode is to find a 93 or 94 build sheet from a car and use the codes on the back of it.
