The brake light won't turn off until you either unplug those relays I mentioned in your other thread, and/or you remove the ABS computer. As long as the ABS computer thinks there's a problem, it'll have that warning light relay turn the red light on.
I believe I also indicated the proper wire to use for the proportioning valve. I'm not guessing, there... I have full wiring diagrams
I can probably get pictures tomorrow if needed.
