95 caravan stumbles and dies
3109 Views 18 Replies 5 Participants Last post by  ka9yhd
I just got my close friend a 95 caravan from a friend at church she lives in NC I'm in sc, anyway she had discovered last week that it would stumble and die sometimes at idle sometimes while driving long distance (hr long or so) it has a mild skip and kinda rough idle, it throws the codes 12,21,23, during the long runs light stays on, I have read the o2 sensor can kill the engine if bad, that I'd a first for me hearing that, based on the info I have and codes I have does anybody have a similar situation and solutions? A direction I can go in without Throwing parts at it anyet information that can help me help her is greatly appreciated :)
1 - 19 of 19 Posts
What engine? What mileage on the van? How long since the last tune up?
A bad O2 sensor can kill any engine - running too rich dilutes the oil with unburned gasoline which can damage the engine.
And** stupid auto correct
Are you sure there was a code 23? Usually the codes start with 12 and end with 55.
Yeah intake air temp sensor and o2 sensor and battery disconnected memory lost within last 50-100 starts
I agree about when was the last tune up? Also has the throttle body ever been cleaned?
I shot carb cleaner in it a couple times it had
Sato for a few years also
It has a minor skip I'm planning on plugs and wiresources soon
Code 12 is insignificant. It is set any time another code is set. Ignore code 12 and do a tune up. It may need an O2 sensor but there could be other reasons for code 12. I'm not sure that 23 is a valid code for that van, but it could be since it's the 4 cylinder.
Reactions: 1
Yeah I'm going to do the o2, next week I found one for 17.00 , I hope it's what is killing the engine if I think of anything else that is going on IL be sure to post it, thanks for the help valiant67 and ka9yhd!
I just looked through the service manual for my 92 Grand Voyager and I do not see a code 23 listed.
12 is something about battery being disconnected and 55 is end of message.
If it has factory ignition wires then you will see a date code on them, such as 1-14 which is for the wires I recently purchased at the dealer.
As for the throttle body make sure you clean out the bore and edges of the throttle plate with an old tooth brush and throttle body cleaner, then hose out the bypass port for the AIS valve, and any vacuum passages.
Code 55 is insignificant, it just means 'end of message'.
Use an OEM O2 sensor if you are replacing it. I have had problems with Bosch and 'Universal' O2 sensors.
Also use the correct Champion Copper Plus spark plugs listed on the underhood label for the vehicle. If this is a 2.5L, check the cap and rotor for wear.
Change the oil and filter as needed if the dipstick smells like gas.
Reactions: 1
IC just a note on the under hood labels. I have seen them with wrong gap listed and on my 92 Grand Voyager with the 3.3 Liter the under hood label calls for RN16 plugs but the Champion book shows RN14.
Based on my experience with my ol' 95, the fuel filter would be the first thing I'd change.
DID that last weekend she drove it shortly after, and same thing happened, but to my knowledge not sense
How do I clean out the vacuum passages, seafoam?
There are two vacuum hoses on top of the throttle body, remove the hoses and spray the throttle body cleaner in the nipples.
1 - 19 of 19 Posts
