95Jeep Grand Cherokee 290,000km pacific north west location.
I was just about to tackle replacing the front end:
U/L Ball Joints + Tie rod Ends + stabilizer shock + Track Bar + Draglink + stabilizer bushings and end links when...
I discovered the rear Driver's side axel mount to upper control arm that sits on the rear axel has separated from the axel. The rear passenger side control arm mount to axel is good.
This should be repaired as I believe it could pose a stability issue if left untreated? The mount has shifted from the original weld points by about 1/8 - 1/4" !
Can it be welded back to neutral position? How does one repair this?
Your thoughts would be appreciated.
