The job wasn't near as bad as I expected. You do need to completely remove the exhaust crossover pipe to allow the tube running under the intake to tilt upwards and come out.
That said ... upon further review, I would have been good with new o-rings. The rust build-up on the pipes was marginal and I think a good seal could have been established. You can't properly inspect the innermost tube unless you literally pull it out so I opted to spend the $70 and buy new tubes.
All is well in SoFla and I got it done before Isaac's bad weather hits us!
