G
Guest
·I have a 3.0 auto tran which gets fed fluid too often ..leak is way to hard to get to,, so when recently I try to get on it a little its like a block under the gas pedal...It will after some time respond but when cold no way..!
also.. unrelated,,////////////////////////////////////////////////////////
////////////////////////////////////////////////////////////////////////// dash brake warning light is on with no brake issues beyond a stuck emerg brake cable. had a line put in recently and then a month later the dash light goes on then off after a bit, first intermittently then last week it would not go out at all..? very disturbing as inspec comes soon!!
thanks in advance Marge
