I've been looking for replacement exhaust pipes for a 1996 Ram 2500 with the V10 and found no aftermarket manufacturers are offering the replacement pipes which come off of the manifolds. In my research I did find that it appears a 1997 Ram 3500 with the 5.9L takes the same pipes.
Does anyone know where I can get these pipes even if they're used from a southern state. I believe the rest of the exhaust from these pipes and back can be made to work with what is available out there. Cats can be swapped for straight pipes as my vehicle is the 8800 GVW, those pipes can go into a dual inlet Cat Back system then.
Any help would be appreciated.
Thanks
Thanks
