Welcome to Allpar. By 'no power to dash', you mean that there are no warning lights, digital odometer/gear display and the gauges sit at zero?
There may be an electrical branch out. You have ignition (spark) and a cranking starter motor? Do you have fuel pressure at the fuel rail test port?
You may need a wiring diagram to trace wire colors and connectors. You checked fuses under both the dash side panel and under the hood?
The auto shutdown circuit is basically only for spark and fuel. If your dash is out, you may have more going on.
