I have a dead left brake light. I thought it was a bad lamp housing because it's flaky regardless of which bulb and holder I use (the van has 6 interchangeable bulbs and holders between the two tail lights). I tried a good used housing and it's still flaky. Turns out to be an intermittent signal at the 5-pin connector. Where does the signal for the left brake light split from the wire from the brake pedal switch to the center and right brake lamps?
Thanks,
Sixto
97 GC SE 3.3 221K miles
Thanks,
Sixto
