My 97 LHS has the blower motor stuck on high
I replaced the engine & after the install the blower motor all of a sudden came on & stayed on high (high only)
I had the key on & was checking voltage readings when all of a sudden the blower came on high & stayed on.
Blower comes on high when the key is turned on & stays on high even if the off buttom is pushed on the climate control panel (the only way to turn it off is to shut the car off or pull the fuse to the blower motor).
Is there a way to fix this?
Do I have to get another climate control panel?
The fan speed control on the climate control panel doesn't change the speed of the blower (even in auto mode)
Nothing was unplugged or spliced or even messed with during the install of the motor & the climate control worked fine before this happened
Thanks for any & all help
