Yes, low voltage was one of the codes I got. I do think at some point I ran the battery down, but it isn’t something that has been a recurring problem. Where or what would I check to determine low voltage? One answer would be to get codes read again, yes.
Update. I checked the pins and connectors and broke part of the solenoid connector. The nut in the center that is used to tighten the connector with came out, looks like the plastic broke and it came out with the screw. So that posses a problem. Not sure that is where the connection problem is or not, but it won’t help. Not sure if I can put some resin in the center to hold it in or not. What I am considering doing is pulling the solenoid off the old transmission and replacing this one. Then I would have the same electrical connector as the original. Concern is if I damaged the old solenoid when my transmission ate itself. Any respectable way to clean them? Do I need a new gasket for this, just some RTV or would it have a re-usable metal type gasket?
And finally, it would appear there is still a leak in the filter pan cover, so I have to address that before I can take it to get codes read. The road between here and there is a strait shot, pretty flat with only one stop sign the end of my street and a light just before the shop, so I can be easy and not cause traffic issues.
Later.
I put the van up on blocks so I could get under it, and I found the fluid leak, it was in one of the hoses going to the cooler. Cut an inch or so off the end and reconnected it. I let it run a while and warm up.
I made sure I raised both wheels off the ground so I could “test drive” it on the blocks. Still the same thing, check engine light comes on about 20-25mph. And I did it a few times, once accidentally with out connecting the solenoid plug, and got the exact same results. Looking like that plug is the issue. Thinking about taking the old one off, just to see what I’m dealing with, and then can decide what to do about the one in the van.
The other thing I realized looking at the codes is this. The codes I need come from the TCM, and I’m going to have to pay another $33 to get them read. I’m thinking my time and money are better spent right now changing the solenoid. Then if I still have codes or issues, I can take it down to get it read. And, changing the solenoid would solve the problem of the broken plug connector. Comments?
