Ok, this is a worst nightmare scenario... I am helping friend piece back her Durango after a shade tree mechanic took advantage of her in my book.
There are so many unknowns to this I would just have her sell me the truck for scrap but she's into it too deep now.. Ok enough of the sob story here's what I'm having trouble with.
For some reason she had the engine changed and every since she had it worked on it has a run on pre-ignite issue and mysteriously stalls, we checked the distributor and it appeared tight, we found a smashed harness to the CSPS and repaired that as well as replaced the CSPS with no luck.
You have to crack the throttle to get it to start when warm after it dies. It only dies at then end of an excel or at a stop sign or turn, it is fine at idle.
When you shut it off it pre-ignites until the engine is warmed up. Then that issue goes away. The only code we are getting is an O2 code. We have a ABS light from the brakes we went thought the brakes for her and haven't dealt with the light yet.
Any suggestions or pointers would greatly be appreciated, I hope he put the right engine in and there is not a CPU problem I haven't checked the vin yet to see if he used the right engine.
Thank you!!
GrayChallenger13
