Have a 98 neon 2.0 sohc that would stutter like it was going to die(usually at stop light)than I'd put it in neutral and keep the rpm's up and be ok.
So I changed the cam sensor and it ran great, then a few days later started doing the same only not as bad yet.
Thing is it will be ok for about 10 minutes or so, and when it does die so far Ive been lucky and it will start up,aleit a little hard sometimes. Had it hooked up to a code reader at the parts store and it was showing cam sensor again,and was told that it could be a faulty crankshaft sensor as the two are incorperated (my words)into the same circut,but so far the car has started up.
Until a week and a half ago I never even heard of said parts,so if things sound sketchy that's kinda why.Thanks in advanced for any info that might help me out.
ullhair:
