Hi Folks,
I have a '98 Sebring Convertible, 2.4L, with the 41TE Transmission. I was getting P0700 and P0740 codes and was checking all the connectors and wiring and replaced the trans fluid. In the process of checking things I messed up the range speed sensor.
So, I removed the lever body on the trans and replaced the speed range sensor. I also replaced the input and output sensors while I had everything out of the way. I reconnected the manual lever and gear cable to the shaft and it is moving to each gear properly with the shifter. I refilled the trans with ATF +4 until it reached the hot zone on the dipstick when the engine was at normal operating temperature.
The car starts up fine, but when I put it in reverse, drive, 2nd or 1st gear, the trans does not engage. It just starts to roll back like it's in neutral. So, only park and neutral are working. This was not a problem before I started working on the car. So, I'm wondering if I did something in the process of re-installing everything.
Any ideas on why my trans is not engaging at all?
Thanks for any help!
