My 98 T& C LXI is leaking gas around the fuel tank inlet area., hard to tell if it is the rubber or if the rust on the fuel filler pipe having a pin hole. But it definitely leaks when the tank is full. Found a brand new replacement on Amazon for $50 made by Dorman that should be good enough for this 15 year old van with 215K miles
But my question is, has anyone replaced one of these before on the long wheel base vans ( mine is made in Dec 97) I see there is a different neck with regard to build date in 1998 year. It looks pretty straight forward but one never knows. Does the fuel filler door have to come off? I appreciate the time to answer this posting!
