hi my sons Dakota's a/c clutch has stopped working, first he noticed an increase in fuel economy then noticed that he couldn't here the clutch engauge anymore, I did a few simple checks, the fuses are all fine, I swapped the clutch relay with the same one used in the horn, but no difference, there are two connections going to the a/c compressor, I unplugged and checked them both and they seemed fine although one had been repaired before in the wire just before the connector with an electrical butt connector but it seemed fine, the compressor pulley spins fine with no growling noises but the clutch wont engauge in either a/c mode or defrost as it did before, any ideas or common problems or maybe some one knows what wires going to the compressor should have voltage, I have a Haynes manual but havn't gotton that far yet as I have a couple other projects I am still deep in, Thanks
