1. My 99 DOHC Neon is due for a timing belt replacement. I am not familiar with the hydraulic tensioner. Is it recommended that I change the tensioner along with the belt and water pump? how do I compress the tensioner to install it? Also, if anyone could post a picture from a manual showing how the camshaft markings need to align that'd be awesome too
2. My speedometer is dancing around, I will check to make sure I have 12v, 5v, and a good ground at the connector. If checked the ohms on the sensor what numbers would indicate a good or bad sensor?
Thanks guys
Thanks guys
