I am experiencing issues related to my ignition switch.
Some of these issues could be related to other faults, but I do know that right now the steering wheel is not locking when the car is turned off. Sometimes when turned off, the odometers remained illuminated and if I don't fiddle with the key (on and off a few times) to turn them off, the battery will be stone cold dead in the morning. Sometimes you must press the key in firmly to get the starter to work when starting it. Daughter said she could not get the car turned totally off or get the key out yesterday.
So, there is the lock cylinder, the ignition switch body ( for lack of a better term) and the plastic, electronic part at the tail end.
Does anyone have any wisdom on which components I should replace? I am thinking that the electronic part at the tail end might not be bad, and that the mechanical part is what has failed.
Never had this sort of issue with any other car so I am blind and need insight.
