Hi,
I have an 99 LHS with broken engine (timing belt skipped due to the broken tensioner bearing) on the road (after overtaking),we found that there is no compression in the LH bank (interference engine >> damaged valves).
Assuming that there is no any defect happened to the pistons and parts under, what are the parts I need to replace?
In my opinion:
Anything more to buy?
Thank you,
Csaba
In my opinion:
- damaged valves
- damaged hydraulic tappets
- valve stems
- (cylinder head gasket)
- (cylinder head screws - upon the status)
Thank you,
Csaba
