Oh well, another air condition 101 question. I put 2 cans of freeon in my 99 sebring w the 2.5ltr v6 yesterday. It was blowing hot air and thered wasnt any freeon in it im sure. The compressor turned by hand. I have a multi meter but am not the best at using it at all yet. When I cranked the car up, the compressor wasnt engaging when I turned the a/c on in the car. I then forced it to come on with a paper clip where the fuse is in that junction box under the hood in the area to the right where the battery is. After I got the compressor going I hooked up the hose from the can of freeon w leak detector and leak sealer. That was a little white can and it seemed to take. So then with compressor still engaged I put the 2nd big can of regular freeon in it. There was a little leaking out at the top of the can where the hose punctures the can but I had just used the same little blue hose to fill up sisters car w freeon the other day and hers took just fine. Hose is ok. So I guess im worried about what to do. Any help is sooo thankful over here. Thanks for any advice or suggestions, a lot!
