You should be able to pull the door trim panel and take a look. Maybe the latch link has popped off?
A phillips screwdriver and wide flatblade (trim stick pry tool) should be all you need. Pry on cold plastic very carefully and gently as it can crack. Warming the interior first may help keep plastic more pliable and you comfortable. If the panel doesn't unfasten from the sheetmetal, look for what may still be holding it.
http://www.justanswer.com/chrysler/1rq57-door-panel-off-1999-town-country-window-motor-controls.html
