Imperial Crown, I already have a full set of the updated barrier hose, the switches I will be using for the fan and safety are actually the ones for the 1993 Caravan and since the car is apart at the moment getting the floor replaced (joy of owning a 32 year old convertible) all seals will be new along with the receiver-dryer and an R134a expansion valve (also for the 1993 Caravan). Since I had owned one, I knew what to look for as factory R134a parts. The hoses were obtained from LKQ when they decided to clear space in their Linthicum MD warehouse and made them available at a discount. Interesting on that TSB, it doesn't show the full text, I was able to scroll around a bit on the site and get the compressor drive belt PN, which from my previous experience on my 1985 was an issue, it would slip the belt unless it was way over tightened even then, with a big fan in front of the car, the belt would flutter like crazy on the drive side.
I do have a complete aftermarket conversion kit complete with the R134a conversion labels. I am hoping I can find an improved seal for the compressor discharge hose set and the suction hose set as the receiver-dryer joints were always a problem on these cars with the thin rubberized aluminum gaskets. I always called Chrysler's engineers a few choice words when adjusting the A/C belt tension, the beautiful alternator and even power steering belt adjustment on these engines, particularly the ones with the ZF pump are great, then the A/C belt tension adjustment is a "what were they thinking?" deal.
Thanks for those links I will update the project thread as it progresses (T2K-CAR rebirth).
