Before I spend big money on finding out what is happening with my A/C, I thought that some of you might have had a similar problem and could give me some things to check first.
You'd think the thing would either work or just quit all together!
(The kill me part
My 2001 Chrysler Sebring Sedan (2,7) is acting up and of course .. it's summertime!
The A/C works intermittently!
Sometimes it will run for a long while but when you shut down to go shopping, you come back and nothing but fan air.
It will either not come back on or it will come on, blow cold for a while (varies on how long) and will shut off again.
At times it's on/off/on .. etc. etc.
Some trips it works fine for an hour at a time but it's a gamble!
Here is something else: Sometimes when you start the car, turn on the a/c, I get a horrible loud squeal .. usually when turning the steering wheel at the same time?
(Is the a/c connected to the power steering in some way?)
I turn the a/c off and back on when I get on a straight path and no squeal?
The a/c will work after that or maybe not!
([email protected] shoot)
As I know nothing about a/c I have some ideas but they are only ideas!
1) low freon
2) something wrong with a thermostat, assuming the a/c has one?
(If the a/c is on high, why would a thermostat come into play?)
3) a belt?
My only other solution would be ...
(The kill me part
1) low freon
3) a belt?
