A/C Question
10K views 6 replies 3 participants last post by  Bob Lincoln
The vacuum removes water by evaporating it and sucking it out, even if you evaporated the flush, it might leave some of the things in solution behind when the water evaporated out of it.
The way to be sure, leave a some of the flush out on a surface or in a container and let it completely evaporate, if it leaves something behind, then the same happened in your AC system.
The guidance for AC is to only flush with another form of refrigerant. Personally I have used 91% Isopropyl Alcohol to flush my AC and NOT had a problem, well other than it taking more than a couple of hours for the system to hold a vacuum because I'm convinced enough was left over and evaporating when I pulled the vacuum.
91% Isopropyl Alcohol will evaporate and NOT even leave a water stain behind.
That might be the way to go get it all out, get a gallon of concentrated near pure alcohol from the hard ware store and fill the parts of the system to dissolve the old flush and then carry it out by flushing with compressed air. Then the vacuum will evaporate the alcohol and water without any residue left behind.
The condenser is the critical thing with R-134a, it needs a more efficient condenser than R-12, so if you have an old R-12 serpentine tube type condenser, it probably isn't nearly has efficient as the newer OEM parallel condensers and you're R-134a performance will suffer.
What would worry me more about residual flush in the system is that, if the pressures and temperatures in the system can cause air and/or moisture to form acids that can eat through the metal, what would it do to the flush? If its citric, I'd think it would be even more likely to form an even more powerful acid, but I'm guessing.
That was my logic in using the 91% Isopropyl Alcohol, even though that is NOT recommended either under most refrigerant repair guidance, it evaporates readily and doesn't leave anything behind, thus anything left should be gotten when drawing the vacuum. Plus, at that concentration its pretty good at degreasing and dissolving any oil to carry out with it as you flush with air.
I'm sure I'm telling you something you already know about the modern parrallel condensers, the materials they are made of and the way it routes the refrigerant through the cooling paths and fins, it is much more effective at dissipating the heat. Something R-134a needs more than R-12.
