You should have a service manual that has the pictures and procedures needed to overhaul the transaxle.
The manual should also describe the necessary 'special' tools. Some arbors, presses and pullers can be improvised from what you may have on hand. The 'birdcage' and 'bearclaw' used a long screw to compress clutch piston springs inside the case.
Don't try an overhaul without a manual.
