HOw does one retain and install the 8 new overun clutch roolers + springs,back into unit without using the Loading tool L-4440?
ImperialCrown said:I've never tried it without the tool.
If you have a transaxle or tool shop that would let you rent it for an afternoon, would be the easiest way. Call around.
ImperialCrown said:It should move fairly freely. One trick is to make sure that the zig-zag spring end contacting the roller is facing away from the drum and towards the case. This will prevent the sharp spring end from dragging on the drum as it rotates. You are using a factory service manual for this reassembly, right?
Vasoline should be ok as a lubricant/assembly grease, although there are specific transmission assembly lubes that may be safer when it dissolves into the ATF after the transmission is put in operation. Is liquid Vasoline considered a mineral oil? Check the bronze bushing and drum contact area for burrs or scratches.
