as mentioned earlier my son and I installed a a833od in his 80 2wd truck, we filled it with dextron as it would have come with from the factory, I also have an older a833 from a cuda, non od,(basicly the same trans), and it came from the factory with 90w gear lube, has anyone ever tried running a different type of fluid in a a833od like say the 90w or synthetic like in the Dakota 5spds, there is not a specific problem here although in a bit of a dumb mistake on my part after removing the side cover for inspection prior to installation I failed to use any rtv over the gasket around the cover,(even though I replaced all the other seals)so we now have a small leak that we have been un-sucessfull in stopping using rtv externally around the cover so I thought maybe a different type of fluid may help here as I have NO intention of removing the trans from the truck again as car show season is now upon us, thanks
