Check to see if you have working brake lights. Check the 10 amp brake light fuse in your fuse block inside the cab. On my 92 Dakota, if that fuse blows, it lights up both the brake warning light and the ABS warning light.
If the ABS fails, will the brakes still work normally--- as if ABS is not present?Bob Lincoln said:Then when you really have a brake failure, you will have no advance warning. Someone besides you could get hurt. NOT a good idea.
On the systems on these trucks, yes. There were a few systems that don't work that way including some early Bosch and Bendix systems where the ABS pump also provided the boost for the power brakes. But these systems which use a traditional vacuum booster will still work as normal brakes if the ABS fails.dak4x4 said:If the ABS fails, will the brakes still work normally--- as if ABS is not present?
