The 5-prong cube relay is standardized and should be the same pin-out. You should see the terminal numbers molded into the plastic. There are a couple of different physical sizes and current ratings.
The dash HVAC controls and rear wiper may be failing. There is a way to calibrate and diagnose the HVAC in Alternative #1, 2 or 3 here:
http://www.allpar.com/fix/codes-climate.html
