Okay, so i have a 98´durango 4*4 5.9 with dual ac.
Yesterday i did a top up with r134a, it still had about 2 bar/ 25 psi in it
but since it was fairly warm and the bottle held a nice 6 bar im rather convinced that i only had
vaporized 134 in there so it was basically empty.
I started filling and the compressor kicked in but i ended up with high suction pressure rather quickly.
- the compressor shut down and didnt want to kick in, it came back after ten minutes....
it seems like adding more refridgerant makes the compressor stop...weird, i do not have high pressure on the hp side. (switch cloosed)
- i have only got about half charge by wheight.
- Its only the rear ac unit that blows cold. ( but it bows really cold )
- both high and low pressure switches are closed with ac off.
- it cycles at 10s on/ 6s off.
What else except the pressure switches/ climate controls controls the compressor?
I also suspect that the front ac expansion valve is broken, thus no cooling at front or can this behaviour be
because of low charge?
- should i just dump the appropiate amount in there and se whats happen?
- How much overcharge can it stand?
It has never been empty or opened so i shouldnt have any air or moisture in it.
By the way refridgerant arent all that easy to come by in sweden so im hesitant to
just waste tha gas.
just waste tha gas.
