I bought an A-Sure aftermatket radio. It is designed as an OEM plug and play model. I'm having 2 issues with it. The first is when I shut the ignition off, the radio immediately shuts down (unlike a stock radio which stays on till a door is opened). Any ideas about this? Also, having a difficult time with Android Auto, it will only function with connected bia USB and does not function when connected to Bluetooth (as it is supposed to). Anyone have this unit? Experienced either of these issues?
Welcome to Allpar. The factory CAN bus set-up keeps the radio on for a select amount of time, or until the drivers door opens through the Accessory relay (R.A.P.).
You will likely need to install a CAN bus interface or emulator to restore radio features and functions handled over the communications bus. This is an example of what you want, although it says discontinued:
Peripheral CHYRAP • Chrysler CAN BUS Radio Replacement Interface for Non-Amplified Vehicles Chrysler CAN BUS Radio Replacement Interface for Non-Amplified Vehicles • Only compatible when removing REF REC RAQ and RAK Series radio • Data controlled RAP Accessory output • Data controlled...
www.sonicelectronix.com
Did you replace one of the Chrysler radios listed above? Do you have steering wheel radio controls?
Some newer aftermarket radio swaps are disappointing because of compatibility issues and mickey-mouse solutions like this. I always try to repair or replace what is in it with an OEM radio.
Thanks... I too wondered if it could be the can bus. The radio actually comes with a wire harness to plug directly into the Cruiser and the harness has a can bus already attached. Maybe it's bad?
I will install one of those into a Dakota this weekend. I had this head unit before they are produced by a Chinese company and other companies simply add their branding. The can bus interface they supply should be universal for Chrysler products from this Era. That said, I have used many can bus interfaces, and none of them work 100%.
The setting on when to turn off the radio should allow for what you want. If they are not accessible from the navigatable menu, there should be a hidden menu you can adjust.
For this particular radio, it may shut off after 10 minutes. Push your key into the ignition and it should turn back on. The ignition switch can be finicky, and after some wear it will lose enough contact for the radio to think there is no key in the ignition. The fix would be replacing the switch.
I mean, my Bluetooth works better then the pioneer touchscreen my Compass has (I didn't install it, I bought it with it already installed by a previous owner).
Thank you all for your input. I finally heard back from A-SURE (apparently they are overseas and on a different schedule than the U.S.). They pointled
out that certain functions of the canbus and how the radio reacts to them can be adjusted through the radio's software. So, I have to go into the programming and change a setting to "Standby" instead of "Off" and then the radio will stay on after turning the ignition off until a door is opened. Hope this info helps incase anyone else installs this unit. Again thanks to you all. And BTW, this is my first Cruiser and I am absolutely in love with it!
I would not use factory power from a 2006 or newer PT Cruiser to drive an aftermarket stereo. You are risking damage to your Totally Integrated Power Module.
To solve your problem including the stereo shut-off issue, read my write-up here:
Yesterday, it was just a small thing. I added a hood security switch. I've never liked that unused bracket with the empty hole. It looks better with a
www.ptcruiserlinks.com
Related Threads
Allpar Forums
757.1K posts
47.9K members
Since 2002
