Is there any way to determine the amperage size of a '70s square back alternator other than the color tag - which is often absent?
FSM says they were anywhere from 34 to 65 Amp (34, 41, 50, 60, 65). This is for my '74 Cuda project. What is different between them - stator? rectifier?
The alternator that was on the car when I got it (some years ago) has no tag. Looks to me to be a rebuild / replaced - I think the date on it is '76.
Then I have a '73 50 amp unit that I picked up at a wreckers some time ago also - it still had the green tag on it. Unfortunately one of the stator terminals is damaged - might be able to fix - but not sure if 50A is good enough or what would have been original to the car. I would guess probably 50 or 60 - no power options - has rear defog, 3 spd wiper - not sure what else is extra - No A/C. I do plan to go EFI so pump will add load - but that will be offset by LED headlights.
I also have another one that is dual pulley - not sure where I got it - probably junk yard too or maybe swap meet. Case is a little different on it from the other two and what the FSM seems to show - the stator laminations are set into the front and rear housing unlike the other two which are just sandwiched between.
I might just buy a rebuilt 60A from Rockauto (Remy or Pure Energy are quite reasonable) to be sure I have a working unit. These appear to be ones with stator set into front and rear housings also.
I see you can also buy stators reasonably priced so I could rebuild one of the old ones with a new stator - but not sure which stator number I would need. The one ad I saw on ebay states one number in the description 3438754 and another on the box 3438768 - both of which appear in the '74 parts book. The parts book lists different alternator numbers but I don't see that it identifies which is which. I don't see any part numbers on the old stators and the alternator case numbers do not seem to be rating specific if I got that right.
Any knowledge appreciated. Thanks
