Following criticism of the styling of the 2014 Jeep Cherokee, Jeep seems to have started testing Cherokee mules with a new, more conventional front clip. If this is correct, the work was most likely started near the end of 2012, when the car was first shown to long-lead media; the changes would be expensive, involving changes to lighting, wiring, durability, cooling, aerodynamics, and crash behavior. This Automotive News photo shows the usual Alfa mule standing in for the Jeep Cherokee, clearly labelled “KL” (the Cherokee’s body code). The headlights have been moved from below the grille to a new position, much higher up, integrated with the turn signals and daytime running lights. The result is closer to the critically acclaimed “teardrop” headlights of the PT Cruiser than to the triple-row lighting used by the much-maligned Pontiac Aztek. The hood and grille are also more conventional, rather than having the “Jeep slots”..
View the original, full post
