Wheels: 18" x 7.0" Gloss Black Aluminum
Tires: P225/40R18 XL AS
Body Colour Crosshair w/Black Surround
Black Headlamp Bezels
Black Shift Bezel w/Accent Stitching
Blue Brake Calipers
Blue Hood, Roof & Deck Lid Graphic
Body Colour Door Handles
Delete Floor Mats
Gloss Black Interior Accents
High Intensity Discharge Headlamps
Bi-Xenon Headlamps
LED Racetrack Taillamps
Lt Black Chrome I/P & HVAC Bezels
MOPAR Blue Accents
MOPAR Body Colour Front Spoiler
MOPAR Exterior Badging
MOPAR Front Splash Guards
MOPAR Performance Exhaust
MOPAR Premium Floor Mats w/Logo
MOPAR Rear Decklid Spoiler
MOPAR Shift Handle
MOPAR Stainless Door Sill Guards
MOPAR Wireless Charging Pad
SIRIUSXM Satellite Radio
1-Year SIRIUS Radio Service
Additional Subscription Fees Apply
For More Info Call 888-539-7474
Radio: UConnect 8.4 CD/MP3
Includes 8.4" touch screen.
This option features:
Feature: Chrome tailpipe finisher
A chrome-tipped extension is attached to the end of the exhaust pipe.
Feature: Sport suspension
A sport suspension is designed to provide taut handling for maximum vehicle control. Features may include higher spring rates, unique shock absorber valving, stiffer stabilizer bars and special bushings.
Feature: Front splash guards
Front splash guards are installed at the rear edge of the front fender behind the wheel well.
Feature: Rear lip spoiler
A lip style rear spoiler is an additional, molded air foil piece attached to the rear of the vehicle. This type of spoiler has no gap between it and the vehicle.
Feature: Black front bumper rub strip or fascia accent
A rubstrip is a separate piece attached to the front bumper or fascia that protrudes slightly from the surface. It is designed to protect the exterior surface of the bumper or fascia from scratches and abrasions. A fascia accent is a decorative application incorporated into the fascia of the vehicle.
Feature: Body-colored grille
The decorative appearance of the opening on the front of the vehicle. Designed to protect the radiator from large debris and to assist in channeling air to the engine compartment.
Feature: Body-colored door handles
The exterior door handles are body-colored.
Feature: Badging
Identifies a model with a distinctive package and enhances appearance.
Feature: High-intensity discharge low and high beam headlamps
High-intensity discharge (HID) headlamps with xenon bulbs for low and high beams produce an intense bluish-white light that more closely approximates natural daylight.
Feature: Front Wheel Diameter
The diameter of the wheel rim, not including the flange or lip of the rim.
Feature: Front Wheel Width
The width of the front wheel rim, not including the flange or lip of the rim.
Feature: Rear Wheel Diameter
The diameter of the rear wheel rim, not including the flange or lip of the rim.
Feature: Rear Wheel Width
The width of the rear wheel rim, not including the flange or lip of the rim.
Feature: Black painted wheels
The front and rear wheels are painted black.
Feature: Aluminum wheels
Aluminum wheels are light and strong.
Feature: Passenger vehicle tire rating
The letter P designates a passenger car tire.
Feature: Front Tire Width
The width of a tire, also known as the "section width". This is the width of the tire in millimeters at its widest point from sidewall to sidewall.
Feature: Front Tire Aspect Ratio
The height of the tire sidewall in relation to the tire width. For example, an aspect ratio of 70 means that the sidewall is 70% as high as the tire is wide.
Feature: Speed rating: H
Speed rated to safely travel at up to 130 mph or 210 kph.
Feature: BSW sidewalls
BSW tires have black sidewalls.
Feature: AS tires
All-season tires are designed to provide good all-around traction and handling, and a smooth, quiet ride in all conditions.
Feature: Front Tire Diameter
The diameter of the wheel rim that the tire can be mounted to.
Feature: Rear Tire Width
Feature: Rear Tire Aspect
Feature: AS tires
Feature: Rear Tire Diameter
Feature: Carpet front floor mats
Front carpeted floor mats are included.
Feature: Chrome instrument panel insert
The instrument panel is accented with chrome trim.
Feature: Piano black console insert
The center console has decorative trim which enhances its visual appeal.
Feature: AM/FM/Satellite
In addition to traditional AM and FM radio reception, this radio, when properly equipped, is capable of receiving digital radio signals from a satellite.
