The 2014 Ram 1500 now leads normally-aspirated V-6 pickup towing capacity at 7,450 lbs. The best-in-class number was achieved fairly simply — by adding a “more robust parking gear” (most likely a stronger pawl) to the eight-speed “TorqueFlite 8” transmission. Mike Cairns, Ram Truck Chief Engineer, wrote, "There was more towing capacity in the V-6 Ram 1500 but we needed to upgrade the transmission to hold the truck and trailer when parked on steep grades. Now that we're building the transmissions ourselves, the improvements are included in the new assembly.” Ram also finalized towing numbers for the exclusive Ram 1500 EcoDiesel. In a 2WD, two-door, long bed configuration, the new EcoDiesel will tow up to 9,200 lbs. The new diesel engine approaches V-8 towing capability with a small but powerful 3.0-liter V-6, and best-in-class fuel efficiency of “better than 25 MPG” on the highway. The gasoline V6 achieves 17/25..
View the original, full post
