Yes, you re-use the cams, phasers, lifters, rocker arms, head bolts and timing chain tensioner. The head comes assembled with valves, oil galley plugs and spark plugs (surprisingly). So far I haven't seen any problems or rechecks with reusing those parts. The only ones I've seen come back are cars that had their heads replaced with another defective head after 20,000 miles.JTE said:Good catch Jake.
Your observation leads to more questions. Chrysler head replacement requires re-using the camshaft?
What other parts are recycled off the bad head and how much labor cost does it add to build up the head vs a straight R-R?
Each cap is machined while installed on the head. It is then numbered and removed for cam installation so it can be placed back in the exact same place. A machine is used to tighten all the caps evenly. These machines are high maintenance and I do recall a time when the caps were not getting numbered properly which generated a lot of scrap. Guess maybe a few got through the system.TJ Jake said:I've seen this happen on a JK Pentastar before. 200 miles before it got towed to my dealership another dealer replaced the head. Pulled the valve cover off and the cam was snapped in half. It's not a problem with the Pentastar design, but the mechanic who worked on it. The cam bearing cap bolts require very little torque, 85 in lbs. if you don't go through the whole torque sequence a second time, some of them will be loose and that's exactly what happened. The last two caps were barely hanging on by the last few threads and the cam snapped right behind the 3rd cap. I have a photo of it somewhere, I'll have to dig for it.
The head got replaced August 12th and the engine ran great for month or so. Slowly running a little rougher. Then towed in Saturday the 14th, the light came on Thursday.TJ Jake said:200 miles before it got towed to my dealership another dealer replaced the head. Pulled the valve cover off and the cam was snapped in half. It's not a problem with the Pentastar design, but the mechanic who worked on it. The cam bearing cap bolts require very little torque, 85 in lbs. if you don't go through the whole torque sequence a second time, some of them will be loose and that's exactly what happened. The last two caps were barely hanging on by the last few threads and the cam snapped right behind the 3rd cap. I have a photo of it somewhere, I'll have to dig for it.
That would be unfortunate I'm already sour on the Jackson's of Enid service department.68RT said:If the caps were left incorrectly torqued, That will cause the cam to break. It looks like yours is an unfortunate re-assembly problem and probably not a design issue.
I got my Rubicon back yesterday after having it towed in on the 14th.68RT said:If the caps were left incorrectly torqued, That will cause the cam to break. It looks like yours is an unfortunate re-assembly problem and probably not a design issue.
