Will an analog cluster from a 95 lebaron convertible plug right into the harness for a digital cluster on a 92 lebaron convertible?My digital has run amok and I found a regular cluster. at the local sy...I have a bad crank seal leak which I'll be fixing this weekend(along with wp and timing belt) I found this when changing oil. Almost no oil cameouit of the pan. !!! ack!! Everything seems to be fine...no weird noises..but the gauge was saying everything was fine. . It goes blank occasionaslly or one part or another disappears. Speedo is really the only thinh I trust on it when it is showing . That and the rpms..It was working fine when I first got it and the only electrical thing I've done is swap out a power lock actuator that was banging like a jack hammer when it activated.. The odd thing is ..when it blanks out ,I can restore it by hitting the key fob buttoms for the locks...weird. Anyway..can I change them???
