My wife's 2003 PT Turbo went into "limp mode" this afternoon on her way home. It has 125,000 miles, and I replaced the ECM in June of 2015 (and the timing belt before that and the turbo a year ago). Of course I purchased the 2-Year warranty on the ECM! Thursday night I was backing it out of the garage and the oil light came on. I checked the code with the Key Dance and sure enough, code P0522 ; Oil Pressure Unit low voltage. So I cleaned the connector with Contact Cleaner, hooked it back up, disconnected the battery to clear the codes. Started her up, ran fine. We have driven the car probably 50 miles since then.
This afternoon, she said it began to drive "funny" and it didn't sound normal (she knows her car well!). It had little power, would not change from 2nd gear and the Check Engine light came on, then the Oil Light. She was able to get it in a parking lot. I performed the Key Dance and pulled P1603, which as near as I can tell, is PCM Internal Dual Port RAM Communications Failure. It is odd that the P0552 didn't register this time.
I had a front wheel bearing replaced at a local shop recently, but that is the only repairs that have been performed by someone other than me. It has been running fine since the ECM was replaced 3 years ago, EXCEPT one instance on the freeway, in the summer heat here in SC, running about 80 mph, when there was a slight hiccup. It was like the engine and all electrical died - for about 1/10 of a second - just a snap of a finger.
So...I am leaning towards another Rebuilt ECM. I purchased this one from Imperial Car Computer Exchange in Cary NC, and feel that the Under hood Heat killed another one. Thoughts? Any additional sources for these ECM units? I truly appreciate any and all input!
