From what I've been told removing the windshield wiper cowl should give you just enough room to access the rear plugs, but even then I believe you'll be working blind. How's it been running?
Back when I had my 2000 T&C Ltd 3.8L AWD I went 148K miles before I changed the original plugs. Ran the same before and after I had the plugs, wires, fuel filter, EGR, serpentine belt and air filter changed (tune up). $150 labor to change the plugs is pretty good. The aforementioned tuneup I had done was $700 (parts and labor). Keep in I had AWD and it could not be accessed from below either.
I run Champion coppers in my '06 Ram Hemi. Recommended change interval is 30K miles. I went 102K miles on one set of plugs - they were worn but not too bad. Currently have about 50K on the current set. Fuel mileage only increased by 0.5 mpg after I changed them out.
