Just wanted to post a thread letting people know that I have at last successfully found a new DC motor that will replace the ones used in all Chrysler auto temp control system aspirator assemblies from about 1987-1993 or so. Maybe more - I'm not sure about other vehicle applications.
What you're looking for is a 12V motor with a 2mm diameter, 10mm length shaft, 10k RPM. Motor body is 27mm wide by 32mm long without shaft or 43mm long with shaft.
Here's the one I just took delivery of: http://www.ebay.ca/itm/DC-12V-10000RPM-27mm-Diameter-Mini-Magnetic-Hobby-Vibrator-Motor-/300962994007?pt=AU_B_I_Electrical_Test_Equipment&hash=item4612cad757
It is a 100% perfect fit and nearly identical to the old Johnson J8719 used in these things. I was able to re-use the old rubber sound covering, housing, and impeller... it all fits the new motor like a glove. At last, the Imperial is about to get a perfectly working ATC aspirator motor. No more worn out yard parts
