well as mentioned earlier I picked up a 1983 Dodge truck 2wd frame complete to install under my 56, this weekend it got a pressure wash, wire brush, inspection, and a fresh coat of black anti rust paint, all looks good except for the right upper control arm which I have to replace then I will probably do the left bushings as well, the frame currently has a 8 1/4 which I am going to replace with the 8 3/4 I had purchased for the original frame but as I wanted to lower the truck I was thinking of swapping the axle. What do most people do about hr perches? cut and re-weld?, there must be specs for this and I am not that confident of a welder, or is there some sort of kit one could purchase?, Thanks
