Jack the car up and remove left front wheel....
Remove ground cable using 15mm socket.....
Using a 7mm socket, remove the screws that hold shield in place....
Remove all six push pins....
Using a 13mm socket remove lower bolt & using a 10mm socket loosen the terminal connections...
Then move bracket to this position...
Using a 13mm socket, remove battery hold down...
Install new battery and reinstall all that was removed..
And a full Wax just because black beautiful!
